Old 10-27-2012, 04:52 PM
jml12305 jml12305 is offline
Default Lift rod question for a 1250
I have a 1250 and I bought a snowplow from a guy local. Got the plow attached and connected the lift rod and found that the plow sits about and inch and half off the ground when the lift lever is all the way forward. Is there something I am missing or just need a longer lift rod.
Old 10-27-2012, 05:05 PM
Longer lift rod. Also a lot of people will set the front and rear tires on 2x4's and adjust the front blade to set on the floor with the tires up an 1 1/2" from the floor. I just used a length of chain from my local hardware store. Just depends on if you want to have down pressure or not.
Old 10-27-2012, 09:44 PM
Here's the guide from the tech section.
http://www.onlycubcadets.net/forum/s...ead.php?t=4616
