Old 10-29-2012, 09:55 PM
jdroison jdroison is offline
Question leaking oil lines to filter on 1811
The lines to the filter have been seeping all summer, took side panels off today to check it out.
I hope it is just fittings seeping but I will power wash it and then run a while to see where its leaking. Are these fittings cub specific or can i get them at a farm supply shop.
Cub Cadets & IH tractors
1811 - 1090 hours
1872 basket case, rebuilding.
#1 tiller
1 Farmall regular
Old 10-30-2012, 06:39 AM
Vince_o Vince_o is offline
I've been replacing mine with the standard filter adapter and engine tin to do away with the lines. I think Cub was the only garden tractor that used remote lines. You can get the adapter new from a Kohler dealer for about 40 bucks, or get them from Joes out door power on epay.
Old 10-30-2012, 08:37 AM
Looks like you have either a loose or cracked fitting or lines. Make sure the fittings are tight.
Clean up the residue and see if you can pinpoint the leak by observing new spillage. Once you discover the exact area, you can either have a new fitting or the whole line replaced.
Old 10-30-2012, 08:46 AM
Mcamp Mcamp is offline
i just installed new lines on 1812 oil filter adapter for neighbor, he got them made at hose shop $30 for the pair. last i checked they were $54 ea from cub
