Old 11-10-2012, 10:01 AM
Default Identify This Lift...
I bought this lift thinking that it was an 82 series lift, but since there are no Frankenstein bolts with it, but a rod, I'm no for sure. It is factory red, or at least appears that way....so if it is an 82 series lift, does anyone have the Frankenstein Bolts that I need to put it on my 782? Thank you for your help!
Old 11-10-2012, 10:12 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
NF lift , looks like mine in the 125. the 82's have a bent S shaped bar
82
Doug
Original , 100 , 125 , 582
Old 11-10-2012, 10:18 AM
Looks like a one off a 782.
Up to 534 and counting...
Old 11-10-2012, 11:53 AM
Frankenstein bolts and nuts, $30 shipped for the pair
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Jeff
Old 11-10-2012, 01:35 PM
ajgross ajgross is offline
Inactive Member
Only the 82 manual lift bars have a bend. The 782/982 bars are straight. that one looks like they bought a 782 lift and put it on a wf. You don't need the small part with the post sticking out. The front of the lift will attach using a pin that is longer than the one that is already in it. To get that pin out, there is a hole in the frame that will line up with the pin if you have the lift at the right position.
AJ
Old 11-10-2012, 02:43 PM
cub123's Avatar
cub123 cub123 is offline
AJ
X2
