Old 11-20-2012, 09:19 PM
Default Sears M18 engine to IH 782 questions
I've found a Sears GT 6000 model #917.255960 with a mag 18 that the seller says runs good but needs carb work. I plan on going to check it out tomorrow and see the engine run first hand. I want to pull the engine and put it a 782. What mods or changes will I have to make to get this to work? Will the electric pto off the 782 go on it without any problems? Will the carbs swap or should I put a #26 on it?
Thanks for any help!
Old 11-21-2012, 06:45 AM
Maybe this question would be better asked in the engine section. I'd post it as "Mag 18 question"
Old 11-21-2012, 07:46 AM
Sam, I reworded the title so maybe it'll catch peoples attention now. It needs to stay here due that it's a sears engine question.
If the engine tag was still on it I would have made searching for info easy.
Old 11-21-2012, 07:52 AM
Duke
I respectfully disagree, it’s a will this Kohler M18 out of a Sears work in my Cub question.
Old 11-21-2012, 08:31 AM
mickb72 mickb72 is offline
Default mag 18
Hello, i put a mag 18 from a AYP(same as sears) in my 582. The crank shaft was 1"x a little longer than it should have been. The best thing was the pto from the 16hp briggs was 1" and bolted to the mag 18 the holes were already there and threaded. I put a spacer out front to take up the extra length.
Worked out great and is stronger than the briggs. Mike
Old 11-21-2012, 08:35 AM
I took the time to do a quick web search and the crankshafts have a different part ## but without more digging, I don't know if it is the Diameter or length.
Guess you might check clutch numbers and possibly they give Diameters.
You would have to use your rag joint stuff prolly but that is just a guess.
I did use a Vert. cub out of a 1720 and go to the work of machining the crank amoung other things to convert it to Horizantal, but it was the same Dia. crank, just longer for the vert.application
I would/did use the old adjustable carb.
Old 11-21-2012, 10:48 AM
Thanks for the replies guys! Looks like I'm going to do it and go from there. I'm going threw red withdraw and want to see this thing move under it's own power.
Old 11-21-2012, 11:02 AM
Once you go red... Well enough said. LOL
Old 11-21-2012, 12:19 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Seen the sears yet?
Old 11-21-2012, 12:30 PM
ROFL
Seen the sears yet?
I'm meeting him at 4pm today.
