Old 11-29-2012, 02:13 PM
cubby102's Avatar
cubby102 cubby102 is offline
Default did a little more to the 782
Well got home from work and wasn't real tired so I decided to put the rear blade on my 782. Only problem was I don't have the cash for the spendy sleave hitch and only had the lower 2 point. Here are some pics...sure.glad I kept some of.my junk
Old 11-29-2012, 02:14 PM
That's nice! The rear blade looks good behind the 782.
Old 11-29-2012, 02:19 PM
cubby102's Avatar
For some reason it wouldn't post more then one in the first post but as you can see it has plenty of power..... No more jack needed. Also the reason I went this rout instead of a sleave hitch is because I can operate it completely seperate of my deck or thrower...so if I'm at my parents throwin snow I can back up to the garage door drop the rear blade and get everything out to hit with the thrower... Or if my mowing and I find a buldge (danged moles) I can smooth it. Or push/ pull dirt and fill in spots without removing the.deck. so what do you all think
Old 11-29-2012, 02:22 PM
cubby102's Avatar
One more... It's all electric and my charging system seems to be able to keep up the ammeter didn't show much of a strain at all as far as it having to kick up the charging and I was using it fairly hard during the test run
Old 11-29-2012, 02:29 PM
cubby102's Avatar
Thanks for the complement. It feels great actually having the drive to do stuff again there for awhile I didn't even wanna look at my cub let alone wrench on em... Now just what to do next. So far I've done zero modifications to rather tractor and only.drilled a couple small holes to bolt brackets to the.implements so really nothing that I can't just take off and leave the.tractors untouched... I'm lovin it
Old 11-29-2012, 02:35 PM
That is too cool! I got a rear blade like yours last week. I plan to put it behind my super.
Old 11-29-2012, 02:56 PM
cubby102's Avatar
im not even sure who made those one but it does look awfully close to yours. Somebody made it into the sleave hitch style so who knows what it was originly. And this one defiantly needs weight/downpressure but it works.great I like it anyway . And I think ye blade would look awesome on that super... Was thinking about turning mine UFO a convertable box blade. I dunno yet
Old 11-29-2012, 03:21 PM
Thanks! Mine is a Craftsman, but it was made by Brinly.
Old 11-29-2012, 10:47 PM
Your IH 782 looks great and it looks like it's got enough power to get the blade down into the ground.
Old 11-30-2012, 09:22 AM
Nice work cubby102
Looks like it has plenty of down pressure
