Old 12-02-2012, 07:20 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default 782d pto switch
Hello. I have a 782d that I am preparing to sell. I put the mower deck on today and the pto will not stay engaged. If I hold the switch up it stays engaged, once I let go it disengages. I am thinking switch but not sure. It doesn't look like an easy job getting the switch out so I thought I'd throw it out there. Any suggestions would be appreciated
Thanks,
Earl
Original, 1512, ih 982, ih 682
Old 12-02-2012, 07:58 PM
Check for corrosion on the switch and relay terminals. Also, if the relay is bad, it will cause those symptoms.
Old 12-02-2012, 08:06 PM
wally67's Avatar
wally67 wally67 is offline
Check all of your safety switches and make sure the are working properly I had this exact problem on my 782D I replaced the switch and the relay and still had the problem I got to checking safety switches and it ended up being the neutral safety switch that the foward/reverse lever operates the little metal tab broke off and was not working properly. I wish I would of checked that before I spent close to $100.00 for a switch and relay that I didnt need. Wally
Cub cadets 100, 128, 582, 1050, #2 tiller, 42" blade, 2-10" Brinly plow, 12" cat0 Brinly plow.
Old 12-02-2012, 09:35 PM
If I understand you correctly,
You are saying that the switch will not stay in the up /on position, it returns to the off position unless you hold it up/on.
if so, it is the switch latch problem,replace the switch to correct the problem.
Old 12-11-2012, 01:31 PM
yesmar74's Avatar
yesmar74 yesmar74 is offline
Sounds like switch to me.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 12-11-2012, 01:50 PM
The culprit is most likely the RELAY. The PTO Switch is doing what it is suppose to do.
