Old 12-14-2012, 11:00 AM
North-Woods North-Woods is offline
Default Rear Lift
I have a 1650 and don't know which lift will fit. Will this one fit?
BRINLY SLEEVE HITCH ADAPTOR KIT BR-H-190 BR-H-193 BR-H-130P-01 BR-H-158 IH 107012 C1 IH 107013 C1 IH 107011 C1 IH 107010 C1
http://ihccw.com/IMG_4575_1.JPG Thanks
Old 12-14-2012, 12:02 PM
Yes, that will work but you need the 3 point on the tractor for that to hook to.
Old 12-14-2012, 12:53 PM
These parts I have named are the actual lifting mechanism or 3 point lift. Where I name the Lift bar, that is the attachment point for the rear most part of the lift bar, I didn't have mine on at the time of these pics. Once you have these parts you can then attach the Sleeve Hitch adapter, which are the items you have listed in your link. You will also probably need to buy Frankenstein bolts to mount the rockshaft to your frame. Jeff in PA, a member here, makes some very nice ones for a great price. I hope this helps. A pic of the back of your Cub will help determine if you need the Frankenstein bolts or if you just need a 1/2" rod to run thru the rockshaft.
All Parts mounted to enable use of Sleeve hitch mountable implements.
