Old 12-18-2012, 02:05 PM
rmunro's Avatar
rmunro rmunro is offline
Default Axle/spindle
Yesterday I performed some maintenance on my 109. I adjusted the steering gear. Much less play. Removed the grease fitting, added another 45 degree in, and much much easier to access. and all the grease isn't squirting out between the housing and the plate.
Now the problem?? Tried greasing the spindles/steering knuckles. Wouldn't take grease. Don't recall that being any issue before. This tractor doesn't get a lot of hours, and is always stored inside. Suspected fitting. Of course the press in broke off flush. Took steering knuckle off and found the bolt is turning inside the bushing, not the bushing inside the spindle. Of course bushing won't move. Can't disable this tractor at this time, need it up and running in case of snow.
Drilled out the old fitting, drilled hole through bushing, installed new zerk. Reassembled and greased.
My question is: If left to work this way, what issues will develop???
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 12-18-2012, 05:15 PM
It'll wear through the bolt and wear out the hole in the spindle. As soon as you get the time, take it apart and do it right.
