Old 12-26-2012, 11:16 PM
Default Where's the Quick in QA42A for a 782?
OK, I tried to mount my QA42A from mrcubcadet on my 782 today for a couple of hours, but wasn't successful. I just can't get the rods to go into the QA mounts under the tractor. Any suggestions or help, besides bringing my equipment to you and dropping it off , would be greatly appreciated! I mounted one to my 149 and I didn't have nearly this trouble....what's the secret? Thanks in advance for your help.
Old 12-27-2012, 12:21 AM
Try loosening the frankenstien bolts a few turns.Removing the subframe from the thrower will help.
Old 12-27-2012, 01:15 AM
I've already removed the Frankenstein bolts, but your second option-removing the subframe-that sounds like a very feasible option. Thank you!
Old 12-27-2012, 01:52 AM
maddog784's Avatar
If you look in the manual, it will show you how to use one of the legs to prop up the subframe. Works pretty slick. Pics are on MattG's website as well. I have tried it personally and it turns it into a relatively simple job.
Best of luck!
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 12-27-2012, 08:29 AM
All good procedures mentioned.
I seperate the subframe from the thrower (2 rods/cotterpins)
It makes it a lot easier on this old man.
A 10 minute job once you get the hang of it.
Just make sure the drive shaft splines are aligned so the yokes are in phase, otherwise it will vibrate/shake.
Old 12-27-2012, 10:38 AM
jr315 jr315 is offline
Can you post pictures of your snowthrower. I have the same one and want to see how everyone else does it.
Old 12-29-2012, 01:11 AM
I mounted it tonight, using the "kickstand" style mount that is described in the manual and in Matt G's website. There was some difficulty setting up the Frankenstein bolts, since I had removed them from the frame and I also had to drive it into the threshold of the garage to lock into the QA hooks, but it is mounted and it was a lot easier than trying to muscle it on. Next step is to hook up the belt and lift mechanism. I'll try to post some pics tomorrow if I can.
