Old 12-27-2012, 08:14 PM
garnold's Avatar
garnold garnold is offline
Default Need to rebuild me snow blowers carb
I'm tired of paying people to do this for me and time to learn. This is a snow king blower with the standard bowl type carb. I should have drained the gas last summer but just tried adding that gas stabilizer stuff. Anyway the carb is gunked up and this is my first rebuild so o could really use some advice plz
Old 12-28-2012, 08:44 AM
brucer95's Avatar
brucer95 brucer95 is offline
My advice is to carefully disassemble the carb, paying close attention to how many turns your adjustment screws are out, clean every single port and passage with carb cleaner spray. Then reassemble and replace the screws to their previous positions. I would add that it does not take much dirt or gunk to mess a carb up, so be sure to take the time needed to fully clean it, and you won't have to do all this over again. Good luck
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706
Old 12-28-2012, 09:07 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
also quit using cheap gas. I know the price of gas bites , but the higher the octane the better. I even add a octane booster to it.
the ethanol in gas today makes moisture, so I also start and run the engines once a month that I dont use all the time. like my 125, I start it on the first Sunday of the month and let it run at 1/2 for 10min or so. if its nice I cruse it around the yard a bit.
Doug
Original , 100 , 125 , 582
Old 12-28-2012, 09:36 AM
garnold's Avatar
Thank you all. It's my own fault for letting this sit around
Old 12-28-2012, 11:08 AM
red56turbo's Avatar
4Speed is correct on the crappy gas. The ethanol ruins alot of stuff. The shelf life of gas anymore is less than 30 days. If I put my cubs into storage, I'll shut off the fuel at the tank and run the cub till the carb runs out of gas emptying the fuel bowl. Then I dump some stabilizer into the tank.
Josh
Diesel Cub Cadets...........
Old 01-02-2013, 08:06 AM
garnold's Avatar
OK maybe not as exciting as most thread updates but got my snow blower working!! Trust me, I get it when I say that I understand this simple task for you vets must sound silly. I'm a deep deep computer nerd so this is like when my mother screams how happy she is that she can cut and paste HAHAHA But for me this is a MAJOR step in the right direction. My uncle came over and we took the carb off. He showed me how the bowl and floats all work. We did the wire in the gas channel thing to clean out the crap. Put it all together and the darn thing started up on the first try! Honestly I was smiling from ear to ear over this small little accomplishment. Now this only makes me want to learn more and lucky for me the pull start ripped off and I have another task to fix HAHAHAHAHA! As always, I thank the kind folks here for holding the hand of us noobs and not making us feel out of place
PS
Any tips on how to actually fix this ripped out pull starter?
Old 01-02-2013, 08:23 AM
4SPEED's Avatar
job well done.
Doug
Old 01-02-2013, 01:08 PM
job well done.
What Doug said!
Old 01-02-2013, 01:15 PM
garnold's Avatar
Thanks guys
