Old 12-28-2012, 02:59 PM
2cubcadets 2cubcadets is offline
Default 100 mowing deck
I need to assemble my mowing deck
On my 100 that I purchased.It appears to
have three cast iron pieces that bolt to
38" deck.I am looking for pics or drawing for
the assembly.
Old 12-28-2012, 08:53 PM
I have a 100 mowing deck that is missing parts. I have a deck and three cast iron pieces. I assume that bearings are pressed into the pieces? I do not
have these bearings or shafts? I don't have a pic of this deck in my manual nor have I found a pic. Does anyone have this style of deck? Or know where I can get info on what I need to put this back together?
Old 12-28-2012, 09:31 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Well, IIRC there are only 2 choices of with deck that may be... one is a 38" the other is a 42". I found this picture of a 38" pin-on cast deck. I believe this is the one that is under the "Attachments" folder for the 100 on Cub Cadet's online microfiche. You could also snoop through the technical library on the forum to see what else can guide you along to what you need.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 12-29-2012, 12:24 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
here is the one that came with my 125. dont think its correct for it, but it worked
Doug
Original , 100 , 125 , 582
Old 12-29-2012, 07:07 AM
The mower decks for that time frame could be one of two. Since you posted no pictures, does you deck have "cast iron" end caps. or not....????
Old 12-29-2012, 10:27 AM
I merged your two threads about the same deck.
Old 12-29-2012, 11:14 AM
Here is the Parts Diagram for the early 38" mower deck....
Old 12-29-2012, 11:40 AM
Default Deck
Hey looks like the diagram could be it
I really appreciate the help everyone.
