Old 01-01-2013, 11:17 AM
nikster's Avatar
nikster nikster is offline
Default How much is too much?
Weight that is.
Got 280lbs., riding on the tractor ( my body weight )
52lbs. On the wheels,
46lbs., on a rear gizmo attached to the rear hitch.
That's 378 total weight on a hydrostatic trans., & that's a lot. Great traction but isn't that toooooooo much pressure/wear for the gears in the rear or trans?
Do others have more?
Is there an suggested weight ratio for the limit?
NIK,
Old 01-01-2013, 11:37 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
my 215lb butt
95lb in each wheel = 405 lbs
the 882 has filled tires with 75lb in the wheel + the 215lb
Doug
Original , 100 , 125 , 582
Old 01-01-2013, 12:04 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
I have 550 extra lbs on my 1200 when i sit on it tires are loaded and 2 sets of weights so 150 a side and my 250. So far so good.ha
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 01-01-2013, 01:02 PM
The best way to add weight is loading the tires and wheel weights. That is rolling weight. Hanging weight on the back plus body weight adds to the stress on the wheel bearings.
On my 125, I have loaded 10.50s, a pair of gilson wheel weight 65 x2=130 plus my 210 lbs.
Old 01-01-2013, 01:11 PM
mmzullo mmzullo is offline
27x12x22 quad tires loaded 145lbs per side
125 wheel weights per side
a Johnny bucket weight box full of weight probably 300 lbs
and My 190 lbs.
this is on my 149 loader.
Old 01-01-2013, 01:16 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
my 982 i have 300lbs of wheel weights 300bls of liquid and me 340 it hell up for ten years now.
Old 01-01-2013, 01:28 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I've got my 180 lbs plus 80 on each wheel on my 100. I have a feeling we're underestimating what the bearing in the axle tubes will carry.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 01-01-2013, 01:29 PM
cuber cuber is offline
Yup Yup the best place for weight is on the wheels!!! Load the tires and put wheel weights on the rims. It saves the bearings a lot and I mean a LOT less stress on the axels
Old 01-01-2013, 02:12 PM
Although our Cubs are well built, some of them are 50 years old. That's a lot of time for previous owners to do some not so nice things with them.
Old 01-01-2013, 02:14 PM
4SPEED's Avatar
x2 you need to keep the weight on the wheels and tires. frame weight is just added wear and tear on the moving parts.
Doug
