Old 01-07-2013, 12:23 PM
Muzzy Muzzy is offline
Default Too quick in reverse.
Hi everyone, I have a 123 that I use for plowing snow. When I run the engine at higher rpm's and shift into reverse it takes off like a shot. Even if I'm careful and go into reverse easy, I'ts still pretty fast. Is there a way to adjust it to be slower?
Thanks.
Old 01-07-2013, 12:28 PM
cubby102's Avatar
cubby102 cubby102 is offline
If your talking about it being jerkey it almost sounds like your trunion is wore out. there are threads on this site that show Tue different ways of fixing it.
Old 01-07-2013, 09:35 PM
I agree, I would check the trunion first. Is it jerky at all going forward?
Old 01-07-2013, 09:47 PM
It's not jerkey or erratic, just fast. Reverse comes on really quick. I'll check the trunion and see if its worn. That's probably it. Thanks.
Old 01-08-2013, 07:45 AM
Let us know what you find out.
Old 01-08-2013, 08:53 AM
Just a thought, maybe the Relief Valve (Reverse) is stuck open. Might want to investigate that also.
Old 01-08-2013, 09:50 AM
mmzullo mmzullo is offline
Maybe the truinion is stuck. Or really hard springs. I have a tractor thats just the opposite. Really slow in reverse. Never looked into it.
Old 01-08-2013, 12:55 PM
I might get into it this weekend. We're supposed to get snow here on friday so, I need to keep it in one piece till then. I read up on the trunion repair and it seems easy enough and while it's apart I can install the rear lift that I have for it. I need to drill the frame for the lift so the fenders need to come off anyway. Thanks, for all the info. You guy's are the best and make things much easier.
Old 01-08-2013, 01:01 PM
cub123's Avatar
cub123 cub123 is offline
Why are you drilling the frame? What kind of lift are you putting on it? The stock rear lift shouldn't require any drilling.
Old 01-08-2013, 01:12 PM
The lift came off of a 126 and the bracket bolted to each side of the frame. My 123 does'nt have the holes in the frame but, everything else looks to be the same.
