Here are a few pictures of my project... this is my first tractor restoration so I won't be moving as quickly as some of the veterans here... I tore this thing down before I took any "before" pictures, but I will share the "during" and "after" shots...
My first stumbling point are these pins holding in the clutch/brake lever and the one holding on the drive shaft. ![]() any tips? thanks in advance, Eric |
Tak a pair of vise grips and hold the break pedal from moving, then get a spirol pin punch (1/4" I believe) and drive them out. They make the special punches that work awesome, but normal drift punch will do the job too. Good luck with it, I am also restoring an O!
- Cory Sanderson -~~- Cub Cadet 104 -~~- Cub Cadet 104 -~~- Cub Original -~~- Cub Lo-Boy 154 -~~- |
Looks like you have a good start.
Looking forward to more pictures of your work. |
those spiral wound roll pins are bad news to get out. when you go to put it back together get new pins. sold at any tractor dealer like Cub /JD. dont use a split roll pin, split roll pins and spiral wound roll pins are not the same.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
The one your driver is pointing to sure looks like a piece of solid rod.
Have you met PBblaster yet? :-) Looking forward to your work John
I knew you guys would know... I'll take a picture of my pile of parts if you would like
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Your off to a great start!
methos... you are right down the road... I live in Sherrills Ford.
Thanks for the pics! Looking forward to your updates.
