Old 01-14-2013, 11:14 PM
2cubcadets 2cubcadets is offline
Default Mowing deck grease seals
I just finished putting bearings and grease seals in my early 38" deck. My question is, do you really need the lower seals?
Old 01-15-2013, 12:19 AM
If you want the grease to stay in, yes...when it gets hot all the grease will probably run out the bottom if you leave the seals out. They are there for a reason.
Old 01-15-2013, 05:21 PM
Default Grease seal
I don't think the grease can run out
It maybe get slung out the seal is located
In the bottom of a welded cup
Old 01-15-2013, 08:00 PM
maddog784's Avatar
The seals aren't there only to keep grease in, they also keep dirt out. Would not suggest leaving them out.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 01-15-2013, 08:28 PM
Default Grease seal
Thanks for everyone's opinion
