Old 01-16-2013, 08:05 AM
nikster's Avatar
nikster nikster is offline
Default 109 vs. 149 ?
Thinking of buying an hydralic lift that came off a #149. Should be able to mount it on my #109 ?
Yes/no?
Any comments?
Thanks in advance
NIK,
Old 01-16-2013, 09:15 AM
It will work just fine if you have or put a ported pump in your 109.
Be sure to get all the parts to make the lift work, some of the indivudal parts are a little hard to find and the cost adds up quickly.
Old 01-16-2013, 09:59 AM
red56turbo's Avatar
Sam's right. You'll need a ported hydro. Most 109's came from the factory without a ported hydro unless they had factory hydraulics. If so, you'll have to swap out hydros.
Josh
Diesel Cub Cadets...........
Old 01-16-2013, 10:10 AM
nikster's Avatar
$$$$$$$$$$ ugh! Seems like this will be a project that will cost toooooo much?
Well got to look at the brighter side, on & off to direct the blade. Exercise is good.
Thanks,
NIK
Old 01-16-2013, 10:51 PM
red56turbo's Avatar
Probably better off keeping your eyes peeled for a parts 149 without an engine. Then you'd have all the parts handy to swap over. I think the 109's and 129's with hydraulic lifts are pretty handy and neat tractors.........
Josh
Old 01-17-2013, 11:57 AM
Muzzy Muzzy is offline
Some plows from MTD,JD,Craftsman have a manual blade tilt that you can operate from the seat. I've often thought about getting one of those or makeing something like that for my cubs.
Old 01-24-2013, 06:27 AM
nikster's Avatar
I had a crapsman with a extended lever type thing to direct the plow left & right. It worked but.............
I don't have enough gray matter to try to come up with the mechanical know-how in trying to rig something like that? But if I saw it 1st. Hand I could attempt it. Or maybe a step by step pictorial in a converted plow to tackle a project like that.
So guyzzzzzzzzzzzzzz, if anyone converts one, take step by step photos to help those out that aren't that mechanicaly inclined?
This would make a good how to project.
Nik
Old 01-25-2013, 08:21 PM
JLM78 JLM78 is offline
I put hydralic left on my 129 not hard at all
