What is the application/purpose/advantage of the carb "spacer" type gasket over the plain single layer thin gasket? I am changing the carb from a walbro to a Kohler Carter # 30 on a K321 engine from a 149,and I am trying to determine which gasket to use.
My K321aqs has the spacer type gasket,but my k241's and k301's have a thin gasket. Thanks.
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
I have gone both ways with and without the carb spacer and really didn't see any notable difference. I think the pullers run a spacer and it probably makes a difference on a modified motor. I beleive it has something to do with atomizing the fuel but not 100% sure. Sam Mac will know more about this topic I'm sure.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
The "thing" that I have always heard, the spacer helps reduce heat to the carb reducing the possibility of boiling the fuel.
the reason for the carb spacer for pulling is because the carb vapour locks and wont run.
| Tags |
| carb spacer |
