Cat 0 box blade
Well, I made my own box blade. I traded for some 3/8" diamond plate for
the box. It's a little heavier than needed but that was all I could find. It weighs in at 188lbs right now. After I add a cutting edge to the front and back it will be more like 210lbs. I'm looking for some 12 or 14" pipe 1/4" thick to make them out of. It ended up being 46" wide. I made the scarifiers from 1/2" x 2" flat bar that I have laying around. They are adjustable and can be raised up and out of the way with out having to flip them over. I have only tried it out once, it's been way to wet here to do anything lately. I did flatten out a couple of dirt piles or should I say mud piles. I don't have enough traction yet to do much, but I think with enough traction it will work out ok. I'm working on weights for the front and some wheel weights. test fitting the draw bar all welded up scarifiers made, may add some wider cutting teeth to them if they don't get the job done on the 189, I'm only getting about 12" of lift after adusting the lift arms. Not sure what to do about that yet.
Chip T. Drexel NC |
Very nice!
Great job on the box blade, Chip!
Very nice!
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
Nice job Chip!
Chip that looks great! For more lift try lowering the top link to the lower holes.
Nice job on the box blade! Looks good behind the "189". Sweet!
Josh Diesel Cub Cadets........... |
Thanks guys. It was a lot of work so I hope it works for me.
I'm only $20 into it plus welding rods so........
Chip T. Drexel NC |
If you need more lift, Fab some longer arms from a set of spares. I had the same problem on my little import tractor. Cut up two spent mower blades and that added about 7 inches to the middle of the lift arms. Game me about 10 extra inches of travel... Its worth a thought
Nroakes Cub Cadet 3206 Kubota AWD garden tractor GR2000 Allis chalmers B112 Bolens GT23 with P.S and hydro blade One big Green tractor Always looking for more projects! |
Looks good. I would suggest hard facing the teeth on those shanks. As well as the bottom of the box itself. It will hold up allot better. Hard facing rod for a stick welder is available at tsc. Good fab work. I really like that 189
