Old 02-10-2013, 08:23 PM
SharkyOhio's Avatar
SharkyOhio SharkyOhio is offline
Default K321 Valve Tappets
I've been tearing down a K321 for a rebuilt. I made a mistake today. After finally figuring out how to remove the camshaft, I got a little too eager and pulled the tappets out before marking them "intake" and "exhaust".
The tappets are hopelessly mixed up, now what? I know I have a 50/50 chance of re-installing them correctly, but how critical is it to put them back in their original position?
Tractor #1--1972 Model 149 with rear lift
Tractor #2--1972 Model 149 with rear lift
1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch
Old 02-27-2013, 12:05 AM
Cjbdvm04 Cjbdvm04 is offline
As far as I know both tappets are identical. They are adjustable so just screw in the adjuster and then back it out until you get the proper clearance.
