Old 02-13-2013, 01:12 PM
mikek mikek is offline
Default Picked up an Engine
I recently picked up a 20hp Kohler Command to go into my 982. Do you guys know of anything to watch out for when putting it in? Will i be able to use the front pro from the onan?
Cub Cadet 2072 w/ 60" deck
Cub Cadet 1872 w/ 50" deck
Cub Cadet 682 w/ 44" deck(Blown Motor)
Cub Cadet 982 w/ 60" deck
Old 02-13-2013, 01:45 PM
Take a look at the link to this re-power, it should answer most of your questions.
http://www.onlycubcadets.net/forum/s...ad.php?t=22444
Not sure if you can use your existing PTO. If the shaft size is the same on both engines and the bolt pattern is the same then probably.
Old 02-13-2013, 03:52 PM
Thanks that should help. The pto clutch from the Onan dosent seem to fit. The output shaft on the Onan is about 3" Long and on the Kohler it is only 1". Any ideas or will I need to get a new clutch?
Old 02-13-2013, 04:34 PM
Leadslingingdaddy's Avatar
You may need to sell that PTO and buy one with the same size pulley that will fit your output shaft...
Old 02-13-2013, 06:22 PM
EricR's Avatar
EricR EricR is offline
Hey Sam,what would you suggest him to do about the drive shaft?
What mods if any to make his fit?
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 02-13-2013, 06:51 PM
Mike
You need to check the shaft length and diameter of that Kohler. If it is only 1" long you are going to have a problem getting a PTO to work on it. Did it come out of a Cub? Most of the Commands are 1” or 1.125” diameter and around 3” long. Not sure but I think most Onans are 1.25” diameter and also about 3” long.
Old 02-13-2013, 07:06 PM
it didn't come out of a cub, the diameter is right but it docent seem to be long enough
Old 02-13-2013, 07:09 PM
Measure it and take a pic of it and I'll see if I can come up with a way to make it work.
Old 02-13-2013, 07:15 PM
alright, ill see if i can get a picture of it tomorrow
Old 03-01-2013, 10:20 PM
Got the shaft extended and now I'm working on the wiring, the wiring from the onan seems to be completely diffrent
