Old 02-18-2013, 05:37 PM
vartz04 vartz04 is offline
Default Best Turf Tire
I am considering pulling my tractor when I am done with it. The place that does a local pull 2 times a year requries turfs on a stock class tractor. If I decide to do this then I will be getting turfs instead of ags for the rear. What turfs are the best for traction?
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 02-18-2013, 06:21 PM
MrGitrdone41's Avatar
I like the Firestone Turf&garden tires the best on turfs. They get alot of grip for a turf tire.
1988 1812,dual ports
1973 108
1968 125
Old 02-18-2013, 09:55 PM
johncub7172's Avatar
Best of both worlds, so you can swap out between ag or turf traction. See if your local puller association will let you cut the turf and remain stock. If so, I'd go that rout.
Most folk sell used turf with rim that still hold air. That's been my experience on both accounts.
Old 02-19-2013, 08:10 AM
mickb72 mickb72 is offline
Default tires
Hello, i saw some Kendas looked like carlises (sp) cx. Guy said they had the best bite of any. Mike
