Old 02-21-2013, 11:50 AM
ssechrist ssechrist is offline
Default Sleeve Hitch
I'm looking for the dimesions on a Brinley sleeve hitch, mainly I'm wanting to know how long the bottom U shaped hitch is. I also need to know how long the lifting bar is that goes from the hitch to the lift handle.
Old 02-26-2013, 12:08 AM
The Sleeve Hitch Adapter is 11" from front to back.
The holes for the draft bolts are 2-3/4" from center to center.
The "Sleeve" is 1" OD.
I have the measurements for the lift bar, somewhere. Need to know if it's a Narrow Frame or Wide Frame
Old 02-26-2013, 12:31 AM
Thank you Yosemite Sam, it's a narrow frame....
Old 02-26-2013, 01:16 AM
Might be a couple of days but I'll root around and find it.
Old 02-27-2013, 05:58 PM
IH Cub Cadet IH Cub Cadet is offline
Great post! I'm thinking about making a sleeve hitch too. I've got both wide and narrow frame CC's, but would put the hitch on my narrow frame 126 first.
Thanks!
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 03-03-2013, 10:47 AM
Jumper Jumper is offline
Sam: Here are some renderings that were posted over the years, I'm pretty sure they are accurate. I hope it's what your looking for.
ssechrist: The first picture is a narrow frame lift bar, I can't find the numbers for a wide frame lift but still looking.
I have only a diagram of a wide frame lift if it helps.
