This doesn't happen when engine is cold. If it has been running and then when I try to start again it sounds like the hydro in engaged and machine tries to move forward when the starter spins? What is the fix? randteed@gmail.com
neutral adjustment link:
http://cubfaq.com/neutraladjust.html
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I followed instructions and I could not get wheels to stop spinning ran out of room in the "u". What should I try now? There is also a lot of play in hydro lever and it seems like there is limited speed in reverse.
sounds like your linkages are worn. It happens. Only solution is to replace them or weld up and grind down to specs the worn pieces.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Here is a little video of the linkage movement. Perhaps this will help in giving me direction. The action looks pretty sloppy but I'm not sure what it should look like. Also the little spring that is in the back part of the linkage was dislodged. I put where it looked like it should go but it doesn't seem to do much. Any suggestions appreciated. http://www.youtube.com/watch?v=k2Jvf4d8-5g
I am not sure this will help you, but I can tell you what I did with my 1650. It had limited movement in reverse, though it didn't try to move in neutral. First, I tried the neutral adjustment, thinking that driving the cam plate down would give me more reverse movement of the trunnion arm. It did that, but the tractor then tried to go in reverse in neutral, so that didn't help at all. I readjusted it back to the neutral position. I observed that the brake rod limited the articulating plate from moving, so I lengthened that so that the brake rod pin never bottoms out in the cam slot. I also lengthened the control rod from the dash lever so it would push the articulating plate more. The combination of lengthening the control rod and the brake rod gave me plenty of power in reverse. Problem solved. Also, make sure your control lever on the dash has sufficient resistance so that the hydro doesn't move it as it will try to do. I'm sure I haven't used the proper terms for the control linkages, hopefully it's descriptive enough for you to figure out.
I'll check that out too, thank you.
