Is there a certain way a Brinly cultivator is suppose to be set up so it works right?
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
YES! Any attachment you HOOK UP to you're tractor need's SET to you're tractor. All tractors have different size tires, hitch's, hitch height's, etc.
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
Well this cultivator is going ton my 105 with 8.5s turfs with wheels weights. I was thinking down pressure was needed so i put solid lifting straps on it.
You don't need down pressure. The way the cultivators are designed they will pull there self down. The wheels are suppose to set depht. Most cultivators you find are missing the wheels, but work really well without them. You just have to keep you eyes on them nd keep adjusting the height. You could make a set of wheels easy enough though.
I have a set with and a set without the wheels. I use the one without the most. I set the rear tines deeper than the front ones but not much deeper than the front. It works fantastic, in fact I just broke ground on the garden with it and it did an awseome job...
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Hi Donovan, Which type of cultivator are you working with, the one that is supposed to have wheels or the one with the big "C" shaped shanks.
I parked my tractor on 4x4's then lowered the cultivator , then set the knifes to the floor in my shop.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Its the one with the wheels, or with the shovels.
It depends on the type of shovels that are on it. You want it set so that when it is in working position the shovels are angled to pull themselves into the ground.
Just my opinion, but a good starting place is that when the cultivator is in working position, the shanks should be straight up and down and the points should be (however deep you want to be) below the tractor tires.
Cheers, Rick
