First used my tiller on a 1250 last spring and found I needed weight on the front while turning when going up hill a little at the end of a row.
So got to thinking later in the summer when I picked up a 1650 that I wanted to dedicate to tilling and this is what I came up with. It incorporates the tiller mule drive into the design and leaves room out fron for extra weight. Will probably use the tractor for plowing also soon as the season opens up this year. Dave S |
Nice work!
Good thing you put a grate bottom in it, I see that being a great place to throw rocks you dig out of the garden!!
Nice fab!! ![]() |
Too cool!!
I want one, no I need one! ![]()
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Nice idea Dave!
You should make a bunch and I would take one off your hands! ![]() |
Great job!
Thanks for the input guys. If Ya decide to build one, the bar/reinforcement in the center need to be a little lower and/or a little further ahead as it's real tight to get you fingers in there to release the quick attatch.
laeeon learned!! Dave |
nice work, looks like it should be there.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
Great idea and build!
It's a rock basket, had on on our IH1566 before we sold it.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
