Old 03-17-2013, 09:01 PM
ccannon222 ccannon222 is offline
Default KT17 II Vs M18 hills
I understand why the KT17 series 1 has so much trouble on hills, but does the series II have problems as well?
Is there any difference in reliablity/longevity between a M18 and KT17 II? I never hear anyone complain about killing M18s because of high operating angle.
Chris
Old 03-17-2013, 09:05 PM
Donovan M.'s Avatar
Unhappy
I haven't had any problems with my M18 on big hills.
Donovan:
62' Original-fenders
Old 03-17-2013, 09:46 PM
M-18's/Series II's have full pressure oiling so it mostly eliminated the oil starvation to the rod bearings.
Old 03-21-2013, 04:50 PM
BanditCub BanditCub is offline
I have a lot of hills that I run the tractor up and down, as well as along the slope and have yet to have troubles; all the hills are at least 1:2 or steeper as well. Mine is a 782 Series II.
Red '84 Cub Cadet 782
50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd.
Old 03-22-2013, 09:38 AM
Thanks for all of the replies.
My current plans are to run the KT17 II until it blows (hopefully a long time) then replace it.
I have a M18 that needs to be rebuilt and I might have access to a good used M18 or M20. If the KT17 blows, I've been debaiting should I go the Magnum route or should I replace it with a B&S Vanguard. I don't want spend a bunch of time and money on a Magnum if it isn't going to hold up any better than the KT17 II.
Also, if the KT17 II is really fragile on hills then I've thought about not even using the 782 to mow once I get my 1250 and 126 back running.
Chris
Old 03-24-2013, 09:15 PM
IH Cub Cadet IH Cub Cadet is offline
Someone correct me, but I think you are good to go with the K17 Series II engines on hills.
I met a fellow recently that had an old JD with the K17 Series I engine in it and I believe it was a high hour tractor - BUT, his yard was totally level!
I think you got a plan - run the K17 till it quits!
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 03-25-2013, 09:43 AM
Chris
Chris
Here is a Vanguard listed on the Roanoke C-list you may want to pick up and put on the shelf for future use.
http://roanoke.craigslist.org/grd/3647542945.html
Old 03-27-2013, 10:49 AM
Chris
Thanks for the lead. It's tempting, however I'm going to pass on it because my wife will kill me if I spend anymore money on Cub parts.
In the past month or so I've purchased a nice 782, 46GT bagger, running K301 to go in a 126, new tri-rib's and 8.50 ags for my father's 122 and other misc parts.
Chris
