I use this
Bi-Polar Plowboy Plowboy X Press
I got a ih-1 from farm and fleet on the 123
No more cubs. But never fear there will be more ![]() ![]() ![]()
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Never forget the last motor i had i didnt brace it an the threads shook into the block then its broke off flush with the block
Kinda Maw & Paw Clampet, but...
I went to Lowe's and bought a 15-inch section of metal sink drain. It was very close to the size of the pipe that screws into the block and it's nice and shiny! Be sure to get the one that has the flange (nut slides onto the pipe and then screws onto the pipe that you are attaching it to) so that you don't have to deal with the threads on the pipe. Now, it's not as thick as some of the pipes available, but it's not nearly as heavy either. It gives our puller a nice pop, without sounding hollow, like the pipe is too large. Here's a couple of pictures. |
The PO used a Farmall Cub muffler from TSC on my 100.
C5rider that what i did with the briggs and it cracked the 90 it shook so much and that what imma try again
Interesting.
I've had mine on for about a year and so far, no issues. I ran the engine a little lean and it heated up the pipe and turned it blue. But, it's still solid. I had thought of putting a flapper on it but decided against it because it isn't that thick and don't want to push my luck with it. |
Yeah an my mount mounts were bad an i had the footwhottle connected to the governor an the motor was unbalanced. Since ive started the new build ive got stuff to make it better an yeah i get this pipe cause i like rhat it changes colors. The briggs i used to have i had it run so hot it turned the whole srack purple. I hooked chains with a gravely an gave it hell cause i had this spare motor to through in
