I'm just wondering why it takes 3 diesel cylinders to make 15hp, and only one gas cylinder to make 16hp? Just kinda popped into my head. What's the advantage of diesel over gas? (other than the cool factor) Do they have more torque?
Brent |
Diesels are better on fuel than gas engines for the most part. And yes, the diesel has more torque, my 1782 pulls better than my 20 HP 982.
Ahh. Didn't take the time to look at the ci of both engines. Makes sense. So the reason a 1 cylinder diesel would "rattle your teeth out" is the high compression??
Being the High compression and compression ignition is the biggest difference between a gas and diesel I would say yes. A basic rule is the more cylinders an engine has the smoother it runs.
A diesel does not use as much fuel as a gas engine. Hence why train locomotives/semi trucks are diesel engines. I've mowed with both a gas tractor and a diesel one. Going from the gas to the diesel I couldn't believe how much the diesel sips fuel.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Even though the HP is nearly the same the torque is no where near the same. I think the 1650 has 31 fl/lbs of torque while the kubota diesel in like the 782D has 44 fl/lbs of torque
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
