Old 03-28-2013, 02:41 AM
mharrison's Avatar
Default Might be the new owner of a 1811
Well long story short, I've got a guy that might be trading his CC 1811 for my 70. He says it runs good and has 900hrs on it. Been kept indoors it's whole life and has the 50" deck with it. He's supposed to be coming over tomorrow to possibly trade. So I was wondering what are things I should be looking for problem wise on his 1811? I'm getting pretty excited moving up to bigger and better things . Is it bad that I'm already picturing it in red
Cub Cadet 149
IH Lawnboy 3321
IH Cub Cadet 782 w/ dual hydraulics-M18 powered
1977 Wheel Horse C-160 8spd w/ 48" deck, dumpcart
Old 03-28-2013, 10:26 AM
Sounds like a good trade. I'd check the tranny bolts, they get loose. Also, check the engine oil, and make sure no gas is in the oil. If gas is in the oil, you may need a new fuel pump, or a carb rebuild. The 1811 will make you a nice tractor. Good luck!
Old 03-28-2013, 10:43 AM
Good luck with the trade. Hope you get it!
Looking forward to pics!
Old 03-28-2013, 10:56 AM
cub123's Avatar
cub123 cub123 is offline
X2
The 1811 is a great cub, my dad really likes his.
Old 03-28-2013, 12:34 PM
badboy1950 badboy1950 is offline
Default 1811
the mag 18s run nice and smoooooth
Dan
Old 03-28-2013, 02:55 PM
dag1450 dag1450 is offline
They are good tractors. Like Allen said look at the bolts that hold the trans/ rear in the frame,they have been known to work loose then people overtighen them and strip out the threds. Also look at engine mounting plate to frame bolts, they also work out. My 1811 had a few engine bolts missing but did not see any damage from this. Good luck. Dave
Old 03-28-2013, 03:48 PM
inspectorudy's Avatar
I've had mine for about three years and it is still going strong. They are real civilized tractors with out a lot of issues to worry about. I added power steering to mine and it made it better but even with the manual steering it is the top of the line three turn system that make turning easier than the two turn models. You can add several things to the rear for more help around the home like my fork lift. I use it to carry heavy things and to mount my electric spray rig on for spring time spraying.
1811 Hydro
Old 03-28-2013, 07:08 PM
Very nice looking cub and attachments!
Old 03-28-2013, 08:32 PM
That's a no brainer. I would also trade him. That was one of the best gas powered Cubs ever built. I sold this one.
Old 03-28-2013, 10:11 PM
I agree! Nice cubs, guys!
