Old 04-05-2013, 03:26 PM
Farmall6 Farmall6 is offline
Default cub cadet 2155
A while back I asked if you could put a tiller on a cub cadet 2155, well I got the tiller rigged up on it and all and it works . But now my problem is traction, I put a set of ags on the back and filled them with washer fluid , but I can only till about ten or so feet before it just starts spinning and I'm stuck . Is there a way I could rig up a independent braking system, or maybe put a locker in it? I don't know that much about hydro-gear hydrostatic trans-axles.Thanks for all yalls help in advance .
Old 04-05-2013, 05:37 PM
Originally Posted by Farmall6 View Post
Okay , so a while back I asked if you could put a tiller on a cub cadet 2155, well I got the tiller rigged up on it and all and it works . But now my problem is traction ,I put a set of ags on the back and filled them with washer fluid , but I can only till about ten or so feet before it just starts spinning and im stuck . Is there a way I could rig up a independent braking system, or maybe put a locker in it? I dont know that much about hydro-gear hydrostaic transaxles.Thanks for all yalls help in advance .
Sorry to be the bearer of bad news but No and No. Maybe some wheel weights would help but you would be better off with something designed to do the job.
Old 04-06-2013, 07:17 AM
The tiller pushes the tractor. Right?
