Here is a photo of the 129 ive been workin' on. it was a basket case, parts and pieces everywhere.
Mark |
Here's another.
Looks pretty good now.
You have a nice 129!
HI Mark, Tell us more about this 129 you been working on. Have you had it long or did you just aquire it? A picture of the hitch area would be nice to see. How does it run?
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
I got it in the fall, could get it to run right, it would run away on its own as soon as it came off idle. Tried to adjust governor, and the governor rod just spun and spun ( broken tab on governor shaft and a trashed gear) remove and freshen motor, rings rod, gear, used shaft, seals head gasket. It runs real good now. previous owner tried to pres s/g shaft out the back of s/g ruining the front cover, had a local shop rebuild it. I put new front wheel bearings in it, and a new hydro fan on ( came with it), rebuilt one of the 2 pto clutches that it came with, changed the hydro filter and oil, and fixed some minor electrical issues. I still have to repair the front axle pivot, and left front spindle ( king pin slop). Currently repairing the reverse hydro relief valve.
Mark |
Nice work Stonewellmark
Here is a photo of the rear lift set-up. i think the lift arm is an old style, so I'll be in search of the new style. I have the hitch setup, just need the vertical arms, probably make my own on the mill.
Mark |
You are correct, you have a narrow frame top casting.
The 129 looks good!
