Old 04-07-2013, 06:01 PM
fer100's Avatar
fer100 fer100 is offline
Default Measurement Need
Those of you that have a wide frame Cub Cadet, I need to know the width of a wide frame, left side end to right side end of the fenders. I know the frames are bigger but does that make the fender measurements wider also? Thanks in advance... Rich
,1 Ariens 934 Hydro with cyclone rake
Old 04-07-2013, 07:12 PM
cubby102's Avatar
cubby102 cubby102 is offline
Worry I don't really get what your asking. You want to know.how wide the fenders.are outside.to.outside?
Old 04-07-2013, 07:44 PM
cubby102's Avatar
31.5 from outside to outside of the fenders on my 1650 if its something else you need let me know I got.a couple fenders not mounted to anything
Old 04-07-2013, 07:49 PM
fer100's Avatar
Yes please, the measurement on a 122 is 29 inches. I purchased a cozy cab and tried to put it on today but its 32 inches needed to bolt it on. I believe that this this is for a wide frame.
Old 04-07-2013, 08:02 PM
cub123's Avatar
cub123 cub123 is offline
The fenders on a 122 are different than a wide frame, however the 1x6-1x7 narrow frames have the same fenders as the wide frames,so its possable its still for a narrow frame.
Old 04-07-2013, 08:06 PM
fer100's Avatar
Thats what I figured. This thing is for a wide frame CC then. If I use it I'll have to make some mounting plates and reconfigue the front so the hood clears and that it clears my N F hydrolic pump on the right. Thanks for the help.
Old 04-07-2013, 11:41 PM
Grampie Grampie is offline
Why don't you look for a tractor to fit your cab? Last summer I took a cozy cab off a large frame bolins and adapted it to fit a 149. I had to extend the bottom of the cab 5" down to the fenders to give me enough head room. Needless to say a lot of work but very well worth it. Anything can be made to fit anything. It just would be alot quicker and easier to find the right tractor like a 149 w/hydraulic lift to fit your cab and by the way, whats wrong with having another Cub around?????????
Old 04-08-2013, 07:34 PM
fer100's Avatar
I do have more cubs but all are 122's. I truely like this model of tractor. I really don't have the tools to do the metal work that I need to do. But Sinse I 've been CUBBING I always wanted a cozy cub. Now that I have one I am on the fence about having it. I feeling like I'am in a Sardine can when I was inside. And it's tight getting in and out. I'am A big Guy!
My worry is that if I start cutting and Trimming it to fit. Ill turn it into a pile of junk. I've been looking the 1" square frame over and the way its designed as lone as I don't cut the frame I'll be ok. But I need a welder to redo the body panels.
