Old 04-11-2013, 05:11 PM
cmatthew's Avatar
cmatthew cmatthew is offline
Default knock under load
at idle runs smooth. forward or reverse, under load theres a knock. full throttle the knock is gone.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 04-11-2013, 06:33 PM
How about a little more info like what engine are we talking about?
Old 04-11-2013, 08:18 PM
He may be talking about the 12hp in his 123? Just as a guess I am going to say the PTO may be chattering a bit if the 3 anti rattle clips are gone.
Found this pic on Google images:
Old 04-12-2013, 10:22 AM
cmatthew's Avatar
sorry. yes its my 123. and those rattle clips are gone. I was thinking also of that being the possible culprit. I haven't been able to find any clips for sale yet. I also did a slight rebuild this winter. everything was in spec. new piston, rings, rod. valves lapped. the knock was there before all of this too.
CC 123
Brinly Lawn Rake
Old 04-12-2013, 10:56 AM
macman81's Avatar
macman81 macman81 is offline
did the crank get measured/turned down? a new rod on an egg shaped crank will knock like crazy at certain rpms/loads. i had a 147 like that.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-12-2013, 01:19 PM
cmatthew's Avatar
rod was within spec so I left it alone.
CC 123
Brinly Lawn Rake
Old 04-12-2013, 03:59 PM
Post a wanted add for those clips. I bet someone here may have some extras.
Old 04-23-2013, 11:23 AM
cubfixerupper cubfixerupper is offline
Talking Regarding knocks
I'm new to cubs but believe my knocking comes from 2 engine mount bolts missing and one other lose causing engine to slap up and down against the frame. Made a terrible noise. Will let you know if it solved the problem once it's up running again. Let me know. Good luck.
