Old 04-16-2013, 06:40 PM
79Puller 79Puller is offline
Default Changed to 48' deck
Ok, I made the change from the 60' deck to the 48. My question is, the pullies on the deck are different sizes the 60 is 6 1/2 and the 48 is 5. Will this be a problem ? If so will the pully on the 60 just unbolt and bolt to the 48. Any other things I should look for. Thanks
Old 04-16-2013, 07:54 PM
dale c. dale c. is offline
the pulley on the 60 is on the center blade spindle,the 48 &54 is a seperate pulley assy. the 48 pulley being smaller will turn the mower faster ,and if i remember correctly the bottom pulley is larger than the top one that the pto belt runs on which would slow it back down
Old 04-16-2013, 09:56 PM
No they are the same size,,,,,will this work having the smaller pulley ?
Old 04-16-2013, 10:51 PM
rweaver rweaver is offline
what model 48 in deck you have they were used on both tractors that used a 4 1/2 in pto pulley and 6in
Old 04-17-2013, 11:44 AM
317 is the deck number
Old 04-17-2013, 09:59 PM
any other thoughts
Old 04-17-2013, 10:37 PM
as far as I can see the 317 deck was used on both size pulleys but most times when they went to the 6 in pto pulley the top pulley was bigger to slow the deck down
Old 04-18-2013, 08:27 AM
So then I should be ok
