Old 04-19-2013, 11:37 AM
tomturky tomturky is offline
Default 122 clutch woes
Another newbie (in NC) with problems. Installed a all new shaft and clutch and drive plates in my 122. I cant seem to get the adjustment right! When I push the clutch in, the plate goes free, when I let it out the drive plates press on the clutch plate like it is suppose to, but when running it wont go in gear. Does anyone have a list of common mistakes in this area?
Old 04-19-2013, 11:46 AM
cubs-n-bxrs's Avatar
tomturkey welcome to OCC. Sounds to me like the rear plate isn't releasing correctly. That is the rear plate that slides a little. Did you put a little lube on that portion of the shaft were the release plate rides?
Old 04-19-2013, 12:11 PM
Good advice Kelly.
Old 04-19-2013, 12:35 PM
Thanx I belive that I did but will re-lube.
Old 04-19-2013, 01:42 PM
Old 04-19-2013, 02:00 PM
It almost sounds like the plates may have been put in the wrong places. The plate with the slotted pin hole goes in the back.
Old 04-19-2013, 02:01 PM
ajcombs's Avatar
ajcombs ajcombs is offline
Welcome to occ!!! page 19 of the PDF on the 100 manual tells you the specs of where the pedal should be. Might have to adjust the brakes to make them work with the clutch correctly as well. Good luck!
Old 04-20-2013, 10:26 PM
Welcome to OCC! Great to see another NC member. Where are you located?
