Old 04-20-2013, 07:32 PM
AuctionMP AuctionMP is offline
Default Front wheel question
I just bought a 1969 107. I noticed that on the right wheel, the valve stem is on the inside of the wheel. The left wheel has the valve stem on the outside (where it should be). Both wheels are mounted the way they should, with the deep side inward. Has anyone encountered this. I will probably weld the valve stem hole and drill a new one on the outside of the wheel, unless I can find another wheel.
Old 04-20-2013, 07:37 PM
That is so you can fill both tires with a short air hose, saves steps.
Actually one wheel is off a WF. Those wheels are common, easily obtained.
Old 04-20-2013, 07:44 PM
Thanks...Do you have any references for buying the wheel??
Old 04-20-2013, 08:20 PM
Check with the sponsors above.
Old 04-20-2013, 08:34 PM
Mlohss's Avatar
Mlohss Mlohss is offline
Deep part goes out on a nf
Old 04-21-2013, 10:40 PM
Originally Posted by AuctionMP View Post
I just bought a 1969 107. Both wheels are mounted the way they should, with the deep side inward.
Presuming of course that we are talking about the wider 5.38" wheels... Is it even possible to put one of them on a Narrow Frame tractor backwards?
