Old 04-21-2013, 07:58 PM
drcjv's Avatar
drcjv drcjv is offline
Default Used hydro Vs putting in new shaft opinions
Just removed the charge pump shaft is shot. I see two options get a used hydro or install new shaft. any thoughts. I believe used pump will be cheaper.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 04-21-2013, 08:04 PM
What tractor are you talking about?
Old 04-21-2013, 09:08 PM
drcjv's Avatar
1572 also can the pump come out without taking out the rear the tractor has a 3pt and rear pto
2072 50" deck
Old 04-21-2013, 09:57 PM
Yes it can come out without pulling the rear but it is not that much more work to pull the whole thing and you can do a better job with it out in the open. Keep in mind that you need the replace it with one from a Super, the output shaft has a different tooth count than the GT pumps.
Old 09-03-2013, 08:57 AM
drcjv's Avatar
Default Driveshaft convertion
I finished drive shaft converstion not too bad. I changed because charge pump shaft was bad and leaking. First I changed hydro pump to newer style. It was cheaper than replacing charge pump shaft. Next I had engine adapter plate made. Non to be found. Cost for plate $50. Took a drive shaft from a cyclops and had to shorten it by about an inch. Last I had collor made to put the two halves together which was another $35. Now it works great no vibration at all.
2072 50" deck
Old 09-03-2013, 12:08 PM
Great news!
Old 09-05-2013, 12:36 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
drcjv, sounds exactly like what happened to my 1572 years ago. The self-centering hearing wore out causing the disconnect clutch to spin out of center. The slinging weight of the clutch wore the pump shaft to an egg-shaped condition until the seal could no longer hold the oil. I too have upgraded the driveline and have gotten rid of the clutch by using a 2000 series shaft.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-10-2013, 10:03 PM
444idi's Avatar
444idi 444idi is offline
what pump did you use and what machine did it come off of. i havent torn my 1572 down yet but i think my shaft is shot as well thanks
Old 09-10-2013, 11:47 PM
rweaver rweaver is offline
Drcjv used a Cyclops pump from like a 1882 then we used 2 1440 drive shafts which he shortened plus all the right parts in between we did not have the part that bolts to the cast pulley he had that made yes I supplied his parts
