Old 04-22-2013, 09:31 AM
scottmi65 scottmi65 is offline
Default Mule Drive Pulleys
I have a 1711 with a 50" deck, I was looking at the mule drive from the top and the pullys are angled slightly. Not sure if this correct or the pully hangers have twisted over time, also the PO put a spacer on the tension bolt I am assumming to get more life out of the belt. Belt # is 754-3003A and measures right at 89". I was thinking of pulling the drive apart and trying to straighten the pully hangers if they are indeed supposed to be straight.
Old 04-22-2013, 09:57 AM
Darrell Darrell is offline
The pulleys are supposed to be angled like that because the drive pulley on the 50" deck sets off to the side , not straight back.
The spacer is no biggee , the PO probably put it on there to take up the slack when you screw the nut down. That rod sets the tension on the belt.
Make sure your belt is in good shape and correct.
Old 04-22-2013, 06:29 PM
Thats what I thought, with the deck pully being offset. The PO took a bolt and bent a hook in the end for a new tensioner so that is why he had a spacer on it. On the original tensioner what is the total length and length of threads?
Thanks
