Old 04-22-2013, 12:37 PM
BeerHunter BeerHunter is offline
Default Cadet SLTX 1054 to move gravel.Comments?
We will be having another 2" of 3/4 Road Crush put on our 900' driveway this summer. The trucks will spread it to a degree but it still needs to be leveled somewhat and spread.
Was thinking of the "snow blade" on the front of the Cadet but am not sure whether or not the snow blade is heavy enough or the tractor will handle it.
Comments , suggestions??
Txs
Old 04-22-2013, 12:54 PM
I wouldn't. I think you would be better off renting a larger machine for the job. Just my 2 cents.
Old 04-22-2013, 01:45 PM
gcbailey's Avatar
gcbailey gcbailey is offline
if you use it, just don't ram into anything too hard...the rear ends on the LTs aren't made for anything "ground engaging"
Gary
Old 04-22-2013, 03:23 PM
sawdustdad's Avatar
I have considerable experience working gravel drives. I maintain our lane and my drive, total close to a mile. I use my blue tractor with a 7 foot rear blade.
Once the gravel is spread, you aren't going to be able to do much with the front blade PUSHING it, (hard to control, digs in, etc) but you can drag it backwards to spread it out. Put some weight on the blade, and drive backwards. OR, drag an old chain link fence gate or metal bed spring with some weight on it, behind the tractor, to level the stone out. With a skilled driver, the spread stone should require little work that a few weeks of driving on it won't cure.
Old 04-26-2013, 01:10 AM
^^ You're right about that!! I too have a lot of experience with dirt/ rock work. I do use the front blade to move rock and dirt, but it is extremely hard to control. It's not like running a dozer, LOL!
Old 04-29-2013, 11:29 PM
IH Cub Cadet IH Cub Cadet is offline
+1
Dragging something or pulling the blade backwards is the way to go. Be careful as your tranny ain't made for ground engaging work.
Not to drag this off topic, but I've got a Wheelhorse tractor and a 50 inch mid mount grader blade. It is a pain in the buttox to put on, but really does a nice job with leveling gravel.
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
