Old 11-30-2009, 07:19 PM
IHinIN IHinIN is offline
Default Cylinder dimensions
Does anyone know the bore and stroke for the optional hydraulic lift cylinder for a 100? I'm thinking it's a 1.5" bore x 4" or 5" stroke. I'm going to build a hydraulic system for my 100 with hydraulic lift as well as a set of remotes on the front to run an angle cylinder for my snow blade. I've got a GM power steering pump so far but that's it. I still need the cylinders, loader valve, and hoses. Also, what's the bore and stroke for the blade angle cylinder? I'm pretty sure it's 1.5"x6". Thanks, Adam.
