Old 04-27-2013, 10:12 AM
gearheadmike's Avatar
gearheadmike gearheadmike is offline
Default Non Cub But Need Some Help/Ideas
Ok i got a 68 TurfMaster 32 (AKA Huffy) And im trying to get it back together but ran into a problem with the bearing/bushing for the rear axle.
Its a belt/chain drve set up so it has a live axle in the rear,and what happen is the po never greased the bearing/bushing so its shot!
I cant fit a newer style bearing as its too big around and i want to try and keep this stock looking. The retainer for the bearing/bushing is spot welded together so i drilled the welds and can hopefully find something to replace it.
Heres some pics of it
Old 04-27-2013, 10:34 AM
Turfmaster was made by Huffy. Huffy was in business from 1950 to 1975. Your best bet is to go here..... HUFFY
Old 04-28-2013, 12:22 AM
So, the center piece that looks like a ball-and-socket... Was it locked to the shaft and turned in the housing? Or did the axle turn inside of it? What material is it made of? From the pics I can't tell if its something similar to Nylatron, or if it was cast..... Could you make a new carrier assembly and just use a flange style bearing?
Old 04-28-2013, 08:43 AM
The axle turns inside and im unsure of what type of metal it is it looks to be regular steel/cast, im trying to brainstorm how to put a pillow block in place of it.
Old 04-28-2013, 09:16 AM
Mike
Try McMaster
http://www.mcmaster.com/#standard-mo...arings/=mimom7
Look at the stamped housing type. Maybe you can use your housing with the bearing from one of these. Other thought is the ball that goes in the links for a 3 point hitch.
Old 05-02-2013, 05:14 PM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
I'm also working on an old MTD with similar bearings on the rear axle. My question for you is how to grease them anyway? I don't see zerk fittings on them. Thanks, Mark
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 05-03-2013, 09:31 PM
Mine im sure is made of steel as its magnetic but it did have a drilled hole for a grease zerk maybe your grease zerk broke off? or is yours brass?
Old 05-04-2013, 01:52 PM
Did you decide how to fix it?.....
Old 05-04-2013, 07:21 PM
Thanks, I looked but no zerk fittings and no holes for one to go in????
1973 Model 149
42" Snow Blade
John Deere X360
