Old 05-02-2013, 12:09 PM
reasondog reasondog is offline
Default CC 149 Timing Marks
Hello;
I think I've read most posts here on this subject,It seems there were a few different markings on the flywheel..On my 149 there is a line on the housing and the only mark on the flywheel is a thin line(nothing above it or below it.No letters or numbers).Upon doing the multimeter trick,it looks like it 0's very close to the line.I am wondering whether the line would be the proper setting or would that be TDC.It starts at that setting but could run a little smoother.
Thanks
Pete
Old 05-02-2013, 02:32 PM
sawdustdad's Avatar
I think you need to keep looking for the S, SP or S inside a circle. Use a scotchbrite pad to clean off the back of the flywheel.
