It appears I am a little low on the trans hydro fluid, What type should I use and also it has a slight milkness to it .....what causes this , tractor has not seen rain or water has been sitting inside
It has condensation in it, time for a oil and filter change.
Drain it and use HyTran Ultra. Look at what Mr. SamMac found in his tubes also.
ok, thanks. I take it the plug is on the bottom of the dif.
There is probably not a drain plug and you can't clean out the case anyway. You will likely need to remove the rear plate and it will drain out that way.
I just did it yesterday on a 1450 and posted some pics, here it is: http://www.onlycubcadets.net/forum/s...ad.php?t=24374 you'll need rear plate gasket and new filter also. make sure you get all the old gasket material removed. BTW I learned most of this searching old threads and asking questions here. good luck.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
Thanks for the heads up, how much fluid do these hold ?
between 6-7 qts. I bought Hy-tran Ultra gallons at a case dealer for about half what cub dealer charged.
The fact that the fluid is milky is a clue that the hydro fluid put in last time was likely not IH/CASE hytran ultra. Instead of going milky, hytran encapsulates the moisture and will just look like blobs or beads suspended in the fluid. Use the good stuff, it's worth it.
Update for ya all, my trans does have a drain plug and I changed the filter and fluid using the hytran ultra, but I put two gallons in and it stills could use a little more, I had lots of milky stuff come out. glad I did the change.
Yeah I noticed my 2082 has a drain by the filter but that's the only one I have with a plug for the hydro.
What model tractor? sounds like alot of fluid.
