Old 12-02-2009, 10:24 AM
BajaGTO's Avatar
BajaGTO BajaGTO is offline
Default QA36A question
There are 4 bolts on the front on the gear box. DO these need to be tightened down? I bought this blower used and it appears that mine have been sliding up and down for YEARS.
Thanks,
Ted
Old 12-02-2009, 12:24 PM
smoker62's Avatar
smoker62 smoker62 is offline
There are 4 bolts in the plate with slotted holes. If these are the ones you are talking about, they are tight but there are spacers so they allow the up and down movement for the belt tensioner. The plate is meant to be lose enough for slide movement.Move your tensioner screw and the plate should slide on the slotted holes.
