Old 12-04-2009, 09:10 AM
wig wig is offline
Default Tiller Pulley Question
I have a #1 tiller that I need help with finding a new pulley on the bottom of the gearbox to take a larger belt (5/8) for my 782. Has anyone ever changed that pulley and if so where can I find one. Thanks
Old 12-04-2009, 04:52 PM
I don't know if they will stock the exact one you need but you can try your local TRACTOR SUPPLY (TSC) ...They normally have a lot of pulleys over between the chainsaws and the hardware section, and over in the farm equipment section by the driveshafts and drive chains they also stock hubs and weld on sheaves.....WHen I needed an idler for my mower deck they had one...
Old 12-04-2009, 05:01 PM
You might try mcmaster-carr. TSC will not have one, because this is a special cast-iron pulley with a rather long hub on it. If you can find one that's essentially the same size but with a 5/8" groove, you should be all set.
Old 12-04-2009, 09:52 PM
wig wig is offline
Thanks for the help Matt, but had already looked in Mcmasters catalog. Like you said it is a very special cast pulley with long hub which is going to be a hard one to find. Any other ideas would be great. Thanks
Old 12-04-2009, 10:05 PM
john k's Avatar
john k john k is offline
I have a #2 tiller with the 5/8 pulley that I want to use on my 125 so my problem is the other way around. Also have not had any luck finding a pulley.
Old 12-04-2009, 11:01 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Why don't you two swap?
I really don't see the issue...but, I haven't looked. The shaft is 11/16", or 3/4" on the gearbox. You really don't need a cast pulley. It's just the strongest way to make it. I'm sure a stamped steel, or even easier to find would be an aluminum one.
You just need one with the right width V design, and a set screw. The original one has three, but that's just for centering. Check the Summit Racing catalog. You mat have to call, and see if they offer one with set screws. Or, check the Pulling Tractors catalogs.
Fly Fishing is not a sport...It's a way of life.
Old 12-05-2009, 08:47 AM
wig wig is offline
I need a larger V-groove for a 5/8 belt rather than the 1/2 belt that my #1 is made for. A trade would be great if the shaft sizes is the same except mine now has a very small chip on one edge of the V-groove, which I might be able to braze back in the piece that broke. Sounds like a #2 tiller might use the belt I need. If you get your pulley off, lets talk. Mine is off. Also I found it hard to pull mine off so I took the cover off the gear box and removed the C-clips holding the gears and then pushed the shaft out the bottom, then used a press.
Old 12-05-2009, 09:58 AM
wig wig is offline
Does anybody have one. Or are they available. If so they are probably very costly. Any does anyone have one forsale or trade for mine? Thanks
Old 12-05-2009, 10:49 AM
wig wig is offline
John do you have your pulley off yet?
Old 12-05-2009, 12:52 PM
DO NOT use an aluminum pulley for this. They are not strong enough. There is a reason these are cast iron. The 5/8" pulley is actually a cast iron hub with a stamped steel pulley on it.
