Old 05-14-2013, 03:30 PM
OhioTractorGuy OhioTractorGuy is offline
Default Lift Arm - 129 Adjustment Help w/Snowblower
My 129 has a snow blower on it and I've had some troubles with the lift arm "locking" in the up position. The arm itself has some play in it, but the little finger thing is rotating out of the little "U" shapes which should keep it up. Is this a fixable issue with an adjustment, or is it simply worn out? I've been digging around and can't seem to find any way to snug this up.
If this is a rookie question, please go easy on m
Old 05-14-2013, 05:52 PM
This may be a rookie question, but I've been around cub cadets for a long time and within the last couple of weeks I noticed a similar problem on my 109... I haven't dug into it yet so I can't answer your question just yet.
Point being, I don't think anyone will come down on you too hard.
Old 05-15-2013, 01:09 AM
How about some pics of it. I think I know where your talking about..... but not sure.
Old 05-16-2013, 01:12 AM
Sounds like a spring issue, if I understand your problem. Try some PBS Blaster to assist the return of it.
Old 06-18-2013, 11:29 AM
I finally had some time to get to the snow blower machine (not a priority in June) and shot some penetrating oil on the mechanism. It seemed to help, but it won't hold the weight of the snowblower in the "up" position, seems to bounce out when I hit the slightest of bumps. Does anyone one know if there are parts available for this machine I'm thinking of rebuilding the entire arm.
Old 06-18-2013, 11:55 AM
cubby102's Avatar
cubby102 cubby102 is offline
If it is indeed wore out the easiestnoption would prolly be to swap out the lift arm with a good one
Old 09-09-2013, 10:19 PM
Unhappy Need Expert Opinion
Okay, as it gets closer to winter I realize I need to get this issue resolved. I dug into this a bit and the spring seems to work much better after I lubricated it and got the gunk out of it. The problem still is that it won't hold the blower up.
As I dug around, it appears the part of the lift handle which acts as the fulcrum has excessive play side to side which is allowing the little " L " shaped thingy to slide out of the teeth. (See part #10 in the diagram from the link below.)
Does anyone know if this is adjustable or perhaps it's just shot? I didn't disassemble it any further at this time.
Welcome to any and all suggestions!
http://www.partstree.com/parts/?lc=c...&dn=0020100025
Old 09-10-2013, 12:26 AM
rweaver rweaver is offline
side to side is wear most of the ones we tear down don't have that its the buttons are broke take your pick
Old 09-10-2013, 09:09 AM
Rweaver- When you face the side to side wear, what is the culprit most times? Any suggestions you can offer are greatly appreciated.
Old 09-19-2013, 03:25 PM
Default How does this come apart?
Ray was kind enough to sell me a nice looking lift arm, now my question is what is the easiest way to swap this out?
I punched out the roll pin holding the lift arm onto the lift mechanism which is under the belly, but it doesn't look like there is enough clearance to slip this off (it hits the foot floor board thingy). Do you suggest more disassembly of the lift mech under the belly or do I need to remove the floor board thingy (Which of course has two remaining screws rusted on and stripped screw driver head)
Thanks to any and all who respond with thoughts!
