Old 05-15-2013, 04:55 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Hydro pump volume/pressure specs?
Anyone know what the specs are for a cub hydro pump? I'd really like to run a hydro powered 110V generator, but I've not been able to find the specs for the pumps ___ GPM at ____ PSI
Thanks
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-15-2013, 05:33 PM
Nominal RPM = 3600
Max RPM = 4000
Charge Pump Volume = .30 cubic inches per revolution
Typical Pressure = 200 #
Max pressure = 600#
Old 05-15-2013, 06:01 PM
Dremel's Avatar
Dremel Dremel is offline
So in 1 minutes at 3600 RPM a typical hydro puts out 4.6 gallons a minute?
3600 x .30 x 0.004329 = 4.6 (and change)
where 1 cubic inch equals 0.004329 gallons
Correct?
Bill
Old 05-15-2013, 07:20 PM
Looks good to me.
Old 05-27-2013, 01:00 AM
fourinchdragslicks fourinchdragslicks is offline
I would be leary of running the hydro for a continuous demand without additional cooling, IIRC there is not sufficient cooling and it will cook the pump. cooling should be sized for at least 25% of input power
http://www.inspectapedia.com/heat/Su...msn_Manual.pdf
Old 05-27-2013, 08:08 AM
4GPM @ 500psi is only 1HP, so 25% would only be cooling for 1/4HP, not much, if the math is not lying!!
Old 05-27-2013, 12:00 PM
hmm, I'm not gonna lie, I did not bother to figure hydraulic hp. however, it is INPUT hp, not output. I guess I would either add a radiator for it, or at least put a temp guage on it
