Old 05-19-2013, 08:07 PM
hondaxr hondaxr is offline
Default Clutch Center Spring
I have a Cub 127 with manual clutch and need a pressure spring (one in it is broken) I have opportunity to buy single PTO pressure spring that fits inside or 2 springs that overlap (they are flat all over)! Question is will the 2 springs work on a 127 clutch? 2 springs seem sturdier!
Old 05-19-2013, 08:08 PM
Would we be correct in assuming you are referring to the PTO Clutch...???
Old 05-19-2013, 09:23 PM
Default reply
Yes the PTO CLUTCH! The spring that WAS in it was IH 483525 R92. The other spring is IH 543969 R1 which is 2. I was wondering if the OTHER springs IH543969 R1 would work on my PTO clutch? PS Those numbers are from http://ihccw.com/pto.html (CUB CADET WAREHOUSE) website.
Old 05-19-2013, 11:02 PM
The simple answer is no they won't fit or work properly.
However, without pictures, after all these years we really don't know if any/all of the parts of your pto are what they are supposed to be.
