Old 05-20-2013, 03:10 PM
ToddW's Avatar
ToddW ToddW is offline
Default 108 clutch not completely stopping shaft spin
Mowed 2 acres this weekend with my 108.
The pedal was all the way depressed and the shaft is still spinning when I shifted. I was able to get by, by slowing the speed down to idle then it shifted fairly easily.
Do not want to grind the gears and this was the only way I got by
How do I adjust the clutch to stop the shaft from rotating?
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 05-20-2013, 03:36 PM
CLA
Clean
Lubricate
Adjust
That is what I do.
Unless the shaft is warped, then R
Replace
Old 05-20-2013, 11:30 PM
When the pedal is down, it should push the bearing into the drive spring on the shaft and create a gap between the bearing and the teaser spring/rear plate. If this happens, then adjusting the clutch will do you no good.
With the pedal down, the rear plate should be able to slide rearward ever so slightly, leaving room for the clutch disk to spin freely between the plates.
It sounds to me like something is binding and forcing the shaft to continue to spin. Either the plates aren't separating or the shaft is sticking in the pilot bushing.
You gotta find out why the shaft doesn't stop spinning when the pedal is pushed down.
Good luck to you.
