So I started by 102 up for the season, took her for a spin, and noticed that the deck seemed to be getting 'hung up' for some reason. After some troubleshooting, I determined the PTO was 'slipping' and at times not even engaging.
Any advice or words of wisdom on what I can do to try and fix it? |
Could be stuck open and just needs a bump to release it, or the spring that closes the clutch is broken. or the release lever is not moving enough to allow the clutch to engage. Probably best to dis-assemble and check it out.
If you don't have any luck adjusting the lever, here is a video on how to remove the PTO clutch. http://www.youtube.com/watch?v=jUol4R9nYAw
Here is the exploded parts sheet http://www.partstree.com/parts/?lc=c...&dn=0011200014 There is a service kit (Cub Cadet 759-3490, $68) that can be ordered that contains a replacement disc, center spring and the 3 alignment springs. You probably will need a throwout bearing too. I'm currently fighting this same battle with my 104 and have it re-assembled, trying to get adjusted. See posts. Good luck. |
Thanks for the info. I went ahead and ordered the kit. Hopefully that takes care of it.
